Help: Part of outside brick wall looks damp - black
Old 12-26-11, 01:52 PM
Post Help: Part of outside brick wall looks damp - black
[IMG]C:\Users\mo\Desktop\2011-12-25 14.06.17.jpg[/IMG]
hi, i recently moved in to this house, now outside in the front garden, under window of the living room, towards the ground, there is a large black patch. i dont know whether it is to with the tree next to it, or wether we might need some kind of an airbrick... ? if anyone can hepl. thanks. picture below...
ImageShack® - Online Photo and Video Hosting
Old 12-26-11, 01:59 PM
Received 1,262 Upvotes on 1,203 Posts
1 Welcome to the forums
2 http://www.doityourself.com/forum/el...-pictures.html
3 Please turn off your Caps Lock
Old 12-26-11, 03:41 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Was there any shrubbery there before you moved in? Looks like there was, and it was removed. The moisture remained as a black spot. It the ground extra wet in that area? Do you see remnants of any plant life like trees, bushes, etc.?
Old 12-26-11, 06:45 PM
C
look at the gutter above that spot
perhaps splashing dirt ?
Old 12-26-11, 06:51 PM
C
look at the left post of the awning
Old 12-26-11, 08:24 PM
chandler's Avatar
Not THE problem, but certainly A problem, unless it has a lexan base and lexan crossmembers.
