Paver Random Pattern
Old 12-29-11, 03:29 PM
Z
I am looking for a good random pattern template that does not have many long straight lines in it, like the one EP Henry provides. Does anyone have a template like this? The bigger the template the better.
I am using EP henry stone and it is Old Town Cobble.
Old 12-29-11, 04:16 PM
P
Received 2,182 Upvotes on 1,952 Posts
There are going to be a certain amount of straight lines, even with a random pattern. How many different size pieces does that cobble have? It looks like it only has two sizes (6x6 & 6x9) which limits your pattern options. I prefer to use a paver with three sizes of blocks (and often cut one in half to make a fourth size) to get a better random look.
Old 12-29-11, 04:22 PM
Z
yes, it only has 2 different size pieces.i just thought that maybe there was some sort of random without the straight lines.
Old 12-30-11, 12:28 PM
P
You just don't have too many pattern options with only two pieces to work with. The good thing is it's a random pattern so you can place them however it looks good to your eye and since they are set dry it's no big loss if you pull some up to change your pattern.
