Is efflorescence common
Old 03-09-12, 03:16 AM
Hi:
I'm investigating concrete block options for a retaining wall project. I spoke with a local Versa-Lok dealer and when I brought up the problem of efflorescence, he said all manufacturers have this problem?
Is this true? I guess I believed this problem was specific to Versa-Lok.
Old 03-09-12, 04:01 AM
Received 840 Upvotes on 737 Posts
I don't know about Versa-Lok but efflorescence is always an issue if moisture can migrate thru masonry.
Old 03-09-12, 05:48 AM
B
Received 47 Upvotes on 43 Posts
Here is a good read on bricks, some say it would describe me at times .
BSI-047: Thick as a Brick — Building Science Information
Bud
Old 03-09-12, 08:49 AM
Received 1 Upvote on 1 Post
Efflorescence is not a possibility just with Versalok since it's possibility depends on the conditions and backfill behind the wall. All of the 4 different major SWR units/systems are made in similar manufacturing systems in the plants they are produced in, but the major licensors do a good job of assisting the manufacturers in production of quality units, while the "knock-off" copy units can be questionable.
Just use a well drain material as a backfill behind the wall and provide drainage.
Dick
