How to fill a hole in brick for Tapcon screw??
Received 0 Votes
I drilled a hole to install a light fixture the thing is I was on an angle when I drilled the hole and now the the Tapcon screw is kind of lose in the drilled hole. Is there a way to foll the hole with some compound and re-drill a new hole? I have no options to move the fixture or to make new holes
You may can insert a dowel, break it off and rethread the Tapcon into the hole. Aside from that you can buy injectable epoxy foundation bolt compound, but it would be expensive for one small hole.
The epoxy is a good idea... they sell the little kits of 2 part epoxy for under $5 at the hardware store. Otherwise you could drill the hole deeper and use a screw that's 1/2" longer. Or go up to the next sized larger tapcon, 1/4" diameter instead of 3/16. The small ones like to spin. In either case, you don't usually want to crank down on them too much, its not like tightening a bolt in steel.
And a rub of a candle on the threads or a shot of silicone (then mostly wiped off) will help keep the screw from being bound in the epoxy. Probably not required...but it's what I do in a case like this.
