Water on garage/shed floor
Old 04-28-12, 04:33 AM
G
Hi I have a problem with water accumulating on the concrete floor of my garage/shed. The shed has a metal roof and sides and was constructed on top of concrete breeze blocks. The floor is 7 - 8 inches below ground level. I have created a 12 inch wide drainage that is now below the bottom of the floor slab. There are no obvious leaks. Hope someone can help.
Thanks
Old 04-28-12, 01:31 PM
P
Received 2,112 Upvotes on 1,891 Posts
Where are you located?
Could it be water condensing and dripping off the ceiling/roof? Is water blowing in when it rains?
Old 04-28-12, 01:41 PM
Received 1 Upvote on 1 Post
Since you did not provide your real location (only non-US), the term "breeze block" may refer to very coarse textured concrete block that are not intended to prevent water penetration.
Being 7" to 8" below grade could be the cause of the water.
Dick
Old 04-29-12, 02:26 PM
G
Hi I'm in the UK, breeze block type I've used is 7n type concrete block. There is a drainage trench around the base a further 7" below the surface of the floor slab.
I've heard about the condensation issues with metal sheds, but this is way more than condensation, 1.5 - 2 UK gallons by the time I have finished moping up.
