Concrete sealer application
Old 05-17-12, 12:08 PM
C
I have an outdoor patio that is acid stained. Last year when I applied sealant, i apparently did not allow it to dry well enough prior to putting on the sealant. I ended up with 'white areas' that i'd like to correct. Will simply doing another application -- this time making sure that the concrete is dry -- eliminate these white areas?
Is there some product i should be using to ensure the concrete is water free prior to installing the sealant?
Old 05-17-12, 01:02 PM
P
was the sealer you applied clear and strong smelling, or milky and almost no smell?
