How to hang plants from brick?
Old 05-19-12, 07:45 AM
P
This is my front porch: http://www.thegamfam.com/images/IMG_1796.JPG
What is the best way to secure hooks to the brick to support some hanging plants?
Old 05-19-12, 12:48 PM
the_tow_guy's Avatar
Received 258 Upvotes on 209 Posts
Masonry anchors; check Lowe's or HD, they'll have a wide selection in the hardware aisle. You'll need a decent drill and masonry bits for the holes.
Old 05-19-12, 07:23 PM
Tolyn Ironhand's Avatar
Received 893 Upvotes on 754 Posts
A hammer drill works best with a masonry bit. You can buy a cheap one, borrow, or rent one.
Old 05-20-12, 03:29 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Brick is a veneer, and depending on the weight of the plant, use caution. You may want to drill through a brick joint and allow your fastener to enter the wood above the brick. I know it will be a long fastener, but with vertical pull and a large plant, just putting it into the masonry may fail. BTW, nice porch. No place for the dogs to get under it though Can't take the country out.......
