Go Back  DoItYourself.com Community Forums > Exterior Improvement Center > Bricks, Masonry, Cinder Block, Paving & Walking Stones, Asphalt and Concrete
Reload this Page >
Which product and how to remove oil stains from concrete(Gas Stations, Parking)
Old 08-17-12, 09:28 AM
G
Hi, I'm trying to look for a product and how to remove oil stains(car oil drops)or at least try to make it as invisible as posible from the concrete, most of it to remove it from gas stations, parking lots and front of houses. I will really appreciate if some one can give me the name of the products and most important how to do it, since I'm out of the US it may be dificult to find the product but I could try to import it or bring it, in one of the trips to the US.
Old 08-17-12, 09:40 AM
Received 1,262 Upvotes on 1,203 Posts
Welcome to the forums
Typically, someone asking this has one stain they want to remove. Am I inferring correctly you plan to remove a lot of stains?
Old 08-17-12, 09:46 AM
G
Thats correct, I have different businesses and the oil stains look very bad so I was looking for a way to remove them or at least make them the most invisible possible.
Received 824 Upvotes on 722 Posts
Most any heavy duty detergent along with a pressure washer will usually get the majority of the oil stains. The longer the stains have been on the concrete, the harder they will be to remove.
Old 08-17-12, 09:54 AM
G
I have a 3500psi hot water washing machine and have used different detergents, it does clean it a lot, but there are some stains that wont go off and I wanted to know if theres something special I can use.
Old 08-17-12, 10:19 AM
Your steam ginny should work better than a PWer. You might try letting a strong detergent solution set on the stains for awhile, then scrub and rinse.
Old 08-19-12, 01:26 PM
BridgeMan45's Avatar
Received 2 Upvotes on 2 Posts
If nothing else, try a small dose of lacquer thinner followed by light wire-brushing of the stains. Has worked for me in the past.
Old 08-19-12, 03:12 PM
GregH's Avatar
Super Moderator
Received 68 Upvotes on 62 Posts
TSP which is short for trisodium phosphate is one product used for this.
It is a powder that you can mix with water and make into a paste.
Scrub the paste into the stains and leave some sitting on the stains overnight.
Try scrubbing again or use the pressure washer the next day.
