Chimmey crown repair
Old 09-23-12, 05:26 PM
I would like to protect the crown on my brick chimmey crown seams to be in good shape not falling apart small cracks would like to know if dry lok is ok for covering to protect
Old 09-23-12, 06:46 PM
chandler's Avatar
Received 3 Votes on 3 Posts
Welcome to the forums! What is a chimney crown? Dryloc is pretty much useless to stop water, although it is tauted to be good. Fill us in on what you are doing and where the damage is located, either outside or inside.
Old 09-24-12, 05:39 AM
Received 166 Votes on 147 Posts
Drylok will seal masonry but would need a top coat of paint to protect it from the weather..... but dependent on the size of the crack it might not bridge the gap. Drylok for primer and elastomeric paint for a top coat does a great job of sealing exterior block or stucco.
I assume the crown is the mortar that goes between the top of the flue and the sides of the chimney. Not sure that paint is the best way to go. Could you supply a pic or two? http://www.doityourself.com/forum/el...-pictures.html
