Basement Wall Leak Under Window
Old 10-25-12, 04:18 PM
T
Exclamation Basement Wall Leak Under Window
Hi, I've got a problem on my hands - when it rains, water comes through a hole in the wall, which is under a window in my basement. This seems to have been caused by two things:
1. The guard outside the window that is supposed to block water had to be removed for safety reasons, but has not been replaced. Photo:
2. The section of wall in question looks like it was patched in the past, and may already have been weak. Photo:
How should I proceed with repairing the wall and the guard? I've never done anything like this so I would appreciate any advice you may have.
Old 10-25-12, 04:27 PM
T
I can't see much of the wall or what it's made of, looks like concrete but your first concern is getting the window well cover replaced ASAP. I see you're in NJ and we may be getting some very serious rain, 5-6" Monday or Tuesday.
Old 10-25-12, 06:14 PM
T
Sorry the pictures got cut off for some reason. Is there any way to remove the existing damaged window well and install a new one without destroying concrete?
