Spots on stamped concrete
  #41
Old 07-11-15, 11:57 PM
kellogg9's Avatar
Any updates? I read your entire thread and was fascinating. One of the guys was definitely spot on here. Your problem at the end disappeared because you re-applied a solvent based sealer. The problem with that is it is temporary. Your white spots will return because you made your sealer thicker. But in time the amount of breathing your concrete does will diminish and the white spots will lessen. Flaking was also another sign btw which happened to you. Wish i was around when it was active
