Best way to cut out a circle in a flagstone patio.
I have a flagstone patio in my backyard. The flagstones pieces are individually laid in a bed of small bluestone. It is not mortared in. I plan on installing a fire pit on the patio. I made a template of the firepit. My thoughts were to lay the template over where I would like the fire pit. From there I would need to cut some of the flagstone and I would install the fire pit. My question, what is the best way to cut the flagstone. Please keep in mind, this is a circular fire pit. Thanks for the advice!
PS: Once the firepit is installed, I will be putting mortar where the fire pit brick meets the flag stone.
THANKS!
THANKS!
Since it is a small radius cut, that would be the obvious.
On paving jobs like curved driveway, parking lots with curved edges, many paver contractor set the smaller pavers, draw a cut line and then use a gas powered blade saw. Same for herringbone or similar patterns even with straight edge lines. Edging materials are put in later and the sanded and/or vibrated.
Dick
Dick
Just wanted to update the thread. The angle grinder with a Dewalt blade worked beautifully. Thanks.
PS: Besides poured concrete, any advice for a base? I recall when I had a walkway installed a few years ago, they used "dry pack". Any advice? THANKS!
SO, I decided that I'm going to leave the base blue stone(dust). Ideally for the first course of the pit, I Wold like to set them so they are firm and level. Should I use cement, concrete, mortar? I'm so confused. Thanks!
