Extending Porch Step. New Concrete over old. Should I split it up? Pictures.
Hi,
I am extending the first step outward because I need to regrade my driveway away from the house. Instead of making an extra step, which is not allowed because of the 6 inch minimum, I thought I could extend the bottom step out to where the lowest concrete is. (See pictures).
Now, I was planning on pouring over it and installing anchors and rebar in both the step as well as the other concrete slab. However, I read somewhere that:
1) I should make sure not to attach the concrete to the bottom slab as this would induce cracking when something moved.
2) I should maintain the split between the steps and the concrete slab
this slab has been here for 30 years and I do not believe it has moved much. Do I still need to maintain that joint (There is nothing in the joint... there was some sand but I blasted it out.
What do you guys suggest? Use the anchors everywhere? Maintain the split?
Happy 4th of July!
Happy 4th of July!
The steps are 7 1/2 inch high. I want to extend the bottom step over the whole slap depicted in the picture. That slab measures 34.5*99.5 inch.
My main questions are.
1) Do I need to form it so the break that is already showing remains there (break between that small slab and the steps.
2) If I do not have to keep that break, can i put anchors in the steps (horizontal anchor) and the slab (vertical anchor) to keep it attached to everything.
3) since the poor will extend the bottom step, do i need to poor it over that step also or just run it against it. If I run it against it it will not overlap obviously. Do i then just resurface? Otherwise I think there might be a vertical crack where the first step now ends.
The reason I am doing this is because the water is pooling there as of now. this is part of bringing up the ground around the porch so that the water flows away.
Temporarily Suspended
I would keep the break. It was probably put there for expansion. The reason that I asked for a picture of the entire stoop was to see if there was enough room on the top to add a step on the bottom by raising the others.
I do not think I want to do that because it would make the project a lot harder.
Pouring the new steps and keeping the joint will make this a lot harder also.
Now i will have a slab on a slab and then another 7.5*7.5*80 inch block lying between the first step and a new slab.
