foundation for bulkhead door?
Old 07-22-13, 07:40 AM
G
Received 2 Upvotes on 2 Posts
one more on this topic -- 18'X18' addition with crawlspace foundation. I'm planning on using the conditioned crawlspace for some storage and so want to add a bulkhead door -- I understand that i need to build a "foundation" for the bulkhead per the mfg.'s specs, and assume it needs to go as deep as the footings etc? thx again for the input!
Old 08-01-13, 04:53 PM
C
Bulkhead doors are typically used for basements and install on concrete foundation plates with steps. For your crawl space entry, a foundation that matched the footing would suffice as you would not want to over dig the entry portal and create a water trap.
