Concrete Slab Moisture
Old 02-18-01, 04:07 PM
Guest
Question
Moisture has penetrated the concrete slab (grade level),and also the plywood subfloor, so am replacing the vinyl flooring due to the staining from the moisture. My question is....how do I prevent this from happening to the new floor I lay down? I don't have the subfloor removed yet, as the builders screwed it down into the cement pretty darn good. And before I remove the subfloor, I should ask if there would be a sealant I could use to keep the moisture from coming thru the old subfloor, or should I replace it.
Thanks for any help.
Old 02-19-01, 08:39 PM
2
First, various methods exist. From injecting liquid vinyl under the slab (outrageously expensive); chemically reacting the concrete to reduce vapor transmission, to topically applied membranes and sealers. In every instance the slab must be repaired.
If you insist on vinyl a topically applied sealer might be secondary backup in addition to chemically reacting the concrete. Another way that might work: a membrane plus a thin concrete overlay.
