Hand rail
Hand rail
I am putting up a hand rail for my neighbor & when i purchased the masonary screws the home depot sales person told me to try the Tapcon screws to hold plate in the brick & cement slab and pick out exactly what he said i needed.
He gave me 1/4" x 1 1/4" screws & told me i needed a 1/4" masonary drill bit which he got for me & not thinking i came home went over to neighbors & drilled the 1/4" holes & all the rest is history holes should have been drilled with 3/16" diameter bit & i can't find a 5/16" screw so how do i fix this.The next size they have is 1/2" & this is not recomended for brick.Thanks for your help
Too bad. They do make LDT (large diameter tapcons) but I dunno if HD has them. I'd say that you should forget that type of anchor and instead go with a sleeve anchor (Trubolt or Dynabolt) that will require an even larger hole (3/8" or 1/2"). It will be a MUCH stronger fastener for that sort of application.
