Asphalt driveway and concrete slab for garage are not level
Old 10-07-13, 10:59 AM
D
I recently purchased a house and the asphalt driveway is 2-3" below the level of the slab of the garage. I need a fairly inexpensive way to bring them closer to level that will get me through the winter. I have to do a lot more work on the driveway, but I'd like to wait until spring.
I've attached a couple of pictures to give you an idea of what it looks like.
Thank you.
Dave
Old 10-07-13, 11:33 AM
P
Received 1,766 Upvotes on 1,579 Posts
Why does the driveway need to be closer to the height of the garage floor?
Cheap & easy would be to lay a board down. If you want to get fancy rip the board at an angle forming a wedge/ramp. Slightly more fancy would be to use some cold driveway patch and build up a ramp.
Old 10-07-13, 11:57 AM
Received 741 Upvotes on 647 Posts
I always thought you wanted a short lip to prevent water on the driveway from running into the garage. I like PD's idea of using a PT 2x
