Just had new walks poured.
Old 10-17-13, 06:00 PM
Roeboat109's Avatar
No surprise to anybody the night the cement was setting some kids did there thing inscribing their artwork in it.It isn't very deep.Is there a way to get rid of it without being drastic or taking a crack on cracking?
Old 10-17-13, 06:38 PM
Without seeing it, it hard to give an opinion.
An Attorney would call a wet concrete slab an "attractive nuisance" (legal term) that invites problems.
Dick
Old 10-17-13, 08:05 PM
Roeboat109's Avatar
wet concrete received message
Its not at all deep just deep enough to barely read message.No color at all just fingerart. Maybe 1/32 of an inch deep.
Old 10-18-13, 03:19 AM
Received 741 Upvotes on 647 Posts
While the concrete is still green a wire brush would probably remove the 'art work' but the steel wire might discolor the concrete
Old 10-18-13, 09:04 AM
BridgeMan45's Avatar
Received 1 Upvote on 1 Post
Wire-brushing will make it worse than it already is, by exposing the aggregate near the surface and possibly displacing some of it. If no curing compound was used on it, you could rub a Portland cement/water slurry (with just a dab of clean mason's sand added) onto and into the entire affected surface using a rubber float.
Sooner the better.
