How to repair cracks in concrete driveway
I live in West Central Florida where we don't have any freezing concerns but driveways still crack from settling. My driveway is almost 25 years old so I don't expect there will be any significant settling in the future. Based on that premise, I would like to repair the existing cracks. Can anyone tell me what the best procedure is to do this? Thanks in advance for your help....buzcar
Without a few pix, it's difficult to come up with an appropriate and specific path forward.
Other than a very generic "Just fill them with the right product after first thoroughly cleaning out any dirt and debris." Not at all helpful, unfortunately.
buzcar -
Bridgeman45 has it right. Make sure it is not omen of a sink hole. There have been a few in that area.
Any other homes in the area with a similar problem? At 25 years old, some cracks can be expected, so a good flexible caulk is best.
Dick
Dick
the ' right product ' would be, according to most fed & state dot conc repr specs, 100% silicone - dow makes 888 [ DOW CORNING® 888 SILICONE JOINT SEALANT ] which has a proven track record + its not expensive in caulk gun packaging,,, ' caulk ' refers to a method & NOT material - no financial interest - dow's w/site has all the directions BUT let's stress CLEAN CRACK SIDEWALLS
Is the DOW CORNING® 888 SILICONE JOINT SEALANT paintable or stainable??? I would like to paint or stain the driveway after I repair the cracks......or would it be better to repair the cracks with Portland cement????
not to my knowledge however it is avail in a conc grey,,, most a/p or hgwy designers don't consider color for jnt sealants :-) our conc's tan up here from the color of the fines,,, you might want to also consider a sika product which is avail in various colors,,, its likely any repr w/conc will crack ( hi-skul fysix - solids expand w/hi temps & shrink w/lo-temps ),,, since your d/w's crack'd, suggest living w/the repr,,, mine is, also, but only measures .003" today,,, IF you're looking for aesthetics, replacement's the best option.
NEVER paint a d/w - there's not a paint made that withstands traffic - auto OR pedestrian,,, IF you're considering staining, you may be able to repr the crks & install a proper jnt pattern retroactively,,, that's difficult to advise w/o pics & dimensions,,, generally, if your d/w's 4" thick, there should be no slab larger than 9' in any direction - rule of thumb
here's another point - stains aren't uv resistant & some colors are NEVER used outside,,, i reseal my every year w/methylmethacrylate-laced solvent acrylic 50% solids ' CSS ' but its only avail from licensed distributors of eliteCrete ( no financial interest )
forgot this - most driveway crks are the result of an improper jnt pattern followed closely by early or heavy loading
cracks in driveway
First of all all of the products are good that above mention ed, i do 2 things (1) clean the cracks real and remove all depre and fill with a backer rod can get all different sizes at your local lumber yard and then use a self leveling filler. (2) again use a backer rod to fill in the cracks and use portland cement with no dand make a slurry , but mix so it is manageble,cover with plasctic and i know you live in florida but still would cover it for about a week bigh,
backer rod performs 1 major function as it prevents sealants from gaining 3-sided adhesion,,, a secondary function is giving the sealant's bottom ' shape factor ' which allows the sealant to expand/contract per design goal,,, the disadvantage is having to saw the crk deeper thereby creating space for the b/r,,, an acceptable alternative is installing tape in the created/sawed crk sealant reservoir,,, portland cement mixes aren't flexible & will crk/lose critical sidewall adhesion,,, whether florida, wisc, or ga, rigid pvmts do change dimension as a result of temp changes - that hy-skoul fizix thingie, remember ? bear in m ind this was our primary work for 20yrs - hgwy jnt/crk sealing/filling per state dot & fed spec'd work
