Sealing stamped concrete
Old 03-01-01, 06:47 PM
Guest
I have a 2 yr. old stamped concrete patio. It was sealed after it was installed, but I would like to re-seal it again as it is getting dull and some areas are losing the sealer. What is a good product to use?
Old 03-02-01, 06:33 PM
2
Best advice: call the contractor and ask what was used. A wide range of good solvent and water borne sealers exist. Mixing sealer types solvent or water borne, ranging from UV stabilized acrylic, polyurethane, epoxy, and silotex, in penetrating/breathable or topical coatings amounts to a chemical experiment. Possibly the mean is UV stabilized water borne acrylic.
