Stoop Repair
Old 04-20-14, 08:29 AM
D
Stoop Repair
Hi,
I recently repaired my stoop. The bottom three steps were brittle and I spend a few hours with a chisel removing all brittle sections. I then drilled holes and put in cement screws and tied them together with rebar wire...there wasn't enough space for rebar itself. I figured this would add a reasonable anchor for the newly applied patch. I used Rapid Set Cement All for the patch. At this point, I am thinking I should cover the entire stoop with a coat of cement so I have a nice covering to prevent water from getting in between the new and old. Do you agree that I should put a skim coat over and if so, what is the recommended thickness? My neighbor thought one inch.
I did buy cement sealer to waterproof it once completely done, but don't want to put that on yet if it's recommended that I coat the entire stairs with cement first.
Thank you!
Doug
Old 04-20-14, 01:14 PM
P
Temporarily Suspended
I wouldn't bother with the sealer.
Old 04-20-14, 04:58 PM
BridgeMan45's Avatar
Received 1 Vote on 1 Post
If you could show us a few pix of what the stoop presently looks like, we'd be in a better position to offer some opinions.
