What Product To Fill Dirt-filled 1 1/4" Pavers Gaps?
Old 07-28-14, 01:44 PM
G
A 6' X 12' paver patio from the late 70's or something. Pavers are 12"x12" X 1.5", not very level or perfect etc. There's soil in the gaps that are 1/4" to 1 1/4" wide and up to 1" deep. I don't know if sand, gravel and weed block material or just dirt is under everything.
wanting a permanent maintenance-free way to keep the weeds out, no round-up spraying, ruining the soil underneath forever with salt, no pre emergents etc.
There's no tree roots near the patio to worry about, but frost heave is possible for a lot of the year.
redoing the whole patio is not an option.
I considered polymeric sand. There are polymerics that say they work in joints up to 4" wide, but the product I can get says these 1 1/4" gaps are too large.
this video uses 1 part Portland type I/II cement to 2 parts masonry sand as a dry mix and presses it hard into the joints and then sponges everything.
http://www.youtube.com/watch?v=TEM0cwDzMro&list=UUUw1S23nlmkUWsCso9HhBAg
Should I add bonder? Should I fill the gaps with sand up to a certain depth and then add mortar or whatever's suggested? Some joints are flush to the top with soil, so how deep should I dig them out to allow for the filler?
maybe even a flexible masonry caulk over backer rod and then dusted with cement for aesthetics, would probable be 10 tubes but no mixing needed and I just want this done.
thanks.
Old 07-28-14, 07:35 PM
P
Temporarily Suspended
I agree with the 2 sand to 1 Portland. That should work.
Old 07-29-14, 06:13 PM
BridgeMan45's Avatar
Received 1 Upvote on 1 Post
How deep does it freeze in your portion of Alabama?
Old 07-29-14, 10:34 PM
G
I find it hard to believe there's no masonry w/ w/o additives that will fill these without cracking (as told elsewhere), so I'm going with the polymeric and checking around to maybe find something that withstands larger gaps than the product I read.
I originally told them sand will come right out and tred everywhere and polymeric isn't guaranteed to withstand such gaps but they opted to gamble with polymeric anyway.
Thanks
Old 07-30-14, 04:49 AM
P
Is it too much work to mix Portland & sand?
Old 07-30-14, 10:55 AM
G
What Product To Fill Dirt-filled 1 1/4" Pavers Gaps? - Landscaping - Contractor Talk
they're saying the gaps are just too large for masonry to not crack.
Old 07-30-14, 12:28 PM
P
Here's another idea. Cut some slices of pavers with a wet saw & insert them in the larger gaps. Then use the Portland & sand mix.
