Outdoor Kitchen and Patio question?
We have decided to put an outdoor kitchen and patio(stamped concrete) in. My question is, should we:
1. Have the guys come in and do the excuvation for the patio, then dig the trenches and run the utilities(gas, water, electric), then have the patio poured.
or
2. Dig the trenches and run the utilities and then have the guys come in and do the patio all at once.
I know this is a bit of a strange question, but the guys doing the patio are really busy and they are kind of just 'fitting us in' and I would like to do as much as possible before they come as I can, but I don't want hinder the process.
1 Note: The land slopes a little to the house right now(not sure if that matters, but it's probably worth noting).
or
I just went through this (1200 sqft stamped/stained concrete). We had the pad built up and leveled in our case about 3 weeks before pouring. We then did the trenches for electrical and poured after filling the trenches back in.
The land sloping toward the house matters a lot - you need to resolve that or water will likely eventually find its way into your house.
Or for sure, the negative slope could at least make a mess of the outdoor kitchen walking surface every time you get a heavy rain. Deal with it now, before the concrete people get there.
The way we did ours is to prepare the area for the concrete, run the service lines, and when the concrete contractor arrived, he compacted everything. The contractor worked around the utilities and finished the floor. The concrete has not moved even in the WNY winters!
I'm a fan of running utilities in conduit. The larger conduit the better to make any potential future repairs easier. It also may allow the option to add another electrical circuit or cable to feed a TV or speakers in the future.
I'm actually not too, too worried about it...The slope is miniumal and I figured they would fix it with the concrete(i.e. excavate less towards the house to compensate the 1in per 4 feet run off).
Also...I am in the process of installing underdecking to keep us dry...the deck is 36'x 20' and the patio will be just a little bit bigger than that....probably like 42'x 21'
