underground tank
Old 08-25-14, 05:24 PM
D
underground tank
I might redo my water system and it would involve burying a 600-800 gallon tank in the back yard close to the house.Just for water storage and it would have a pump inside it.
I wondered if a plastic tank would be safe in the ground 6 ft down from animals or is concrete
or metal the only appropriate choice. what do you think??
a solar powered well pump would slow fill the tank...
Old 08-25-14, 05:57 PM
Received 3,422 Upvotes on 3,068 Posts
What you will be using the water for is a deciding factor. Is the water for potable use ?
Old 08-25-14, 06:31 PM
Received 1 Upvote on 1 Post
many tanks you see standing above ground are concrete coated on the inside,,, i'd use plastic underground - cheap & easy to move w/o heavy equip,,, if the system's sealed, how would any animals get into it ? would never choose metal
Old 08-26-14, 07:01 AM
L
I would use plastic. Make sure the tank is designed for direct burial!
Old 08-26-14, 08:46 AM
P
Received 1,768 Upvotes on 1,581 Posts
Make sure you include an access hatch for cleaning and access to the pump and float switches.
Old 08-26-14, 12:33 PM
central tractor has a decent selection - even have hatch size covers
Old 08-26-14, 05:31 PM
D
yes its for potable........................................................
