Tiling over roofing paper? Suggestions
Old 09-17-14, 08:08 AM
N
I am in the process of renovating an apartment, which has a substantial amount of outdoor space. Here are the basic facts: The apartment is on the second floor. The previous owner added a cellar extension to the building. The roof of that cellar extension is also a deck/patio for my apartment. The roof of the extension is concrete. It started to leak years ago and the concrete was covered with tar and roofing paper. I would like to tile over a large section. Is there any reason I can't use wire mesh and thin set to go over the roofing paper? How secure does the wire mesh need to be to the ground underneath it. I am pretty sure I could staple the wire mesh to the roofing paper, but it clearly can't be stapled to the concrete under the paper. Would I need to anchor the mesh into the concrete? Any suggestions would be greatly appreciated. Thanks.
Old 09-17-14, 09:38 AM
BridgeMan45's Avatar
Received 1 Upvote on 1 Post
Without anchoring the wire mesh, your tile job will start to wiggle over time, as heat and cold cause things to change dimensions. I would anchor the mesh using whatever is used in the industry for that purpose, to avoid a perpetual task of re-grouting tile joints.
Old 09-17-14, 03:24 PM
no exterior tile in ny unless you want your tile grout to crack from infiltrating water which will turn to ice,,, where'd you get this idea, anyway ? it only looks nice in magazines which show homes in fl, ca, az, & nm,,, we made a decent living removing tile from augusta ( ga ) decks & restoring the underlying concrete.
better you should find a traffic resistant membrane & use adhesive to hold it in place,,, we just finished a deck using ' duradek ' - it seems like a good product [ no $ interest ]
Old 09-17-14, 04:30 PM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
Yeah, I can't see any way a walk on tile surface would work here. Many other options would be better.
Old 09-18-14, 12:55 AM
if you're bound & determined to do that, put some pavers in place & build a perimeter frame out of p/t'd or cedar/redwood 2x4's,,, @ least you'll have a place to put your tushie,,, your also stand a better chance of not destroying what obviously was a failed ignorant attempt to repair a leaking concrete slab by someone else,,, don't compound the error by following your action plan
Old 09-18-14, 08:47 PM
N
Thanks for the suggestions/warnings. I will look into other options.
Old 09-19-14, 03:31 PM
make certain you address dead/static/dynamic loads,,, can't have you falling thru the floor of your new very fine sundeck
