Concrete Driveway Stain
Hi,
I had a channel drain installed across my driveway to prevent water from reaching my home foundation. They did a crappy job but that's another issue. I noticed that the concrete around the channel drain is a lighter color than the rest of the driveway. I also noticed footprints from the workers that are a lighter color too. I assume it was from the water of the wet saw mixed with concrete or the concrete they used when putting the channel drain in.
My question is what can I use to remove these stains.
Thanks,
Doug
Thanks,
Doug
not much as the original conc's 1 design mix & the slot drain conc probably came in apron/vest store bags,,, hopefully the footprints will eventually wash off,,, MAYBE a pressure washer would help,,, we often have the same issue - its a ' managing expectations ' issue more than anything else
