wait time before painting new block wall
Received 0 Votes
I built concrete block skirt around cottage. Do i have to wait 28 days for mortar to cure? Some cells filled with concrete. Remainder filled with damp sand. Painting so property tax guy does not see it.
As long as the mortar is good and dry you can apply block fill and paint [usually the next day] If you stucco'd the block - wait 3 days before priming/painting.
Just because it's painted doesn't mean the tax assessor or permit inspector won't notice.
A lot is dependent on where you live. Some areas require permits for everything
When I moved from central fla they were discussing requiring permits for any paint job that cost $1k or more
Where I live in tenn they're fairly lax in the county although some of the nearby towns are stricter than others. Often when underpinning a house with masonry you have to have the footer permitted and inspected.
never heard a coat of paint would increase the assessor's property tax valuation,,, why not coat it w/grey thoroseal - its not paint so will stand up much better than paint,,, just in case the valuation icreases, filing a grievance will easily get it dismissed BUT the responsibility's YOURS - NOT the assessors'
The OP replaced rotten wood underpinning with concrete blocks which could affect the tax assessment.
The $1k paint job permits were all about tax revenue, many of the bigger paint contractors were fighting it when I moved - I don't know if they were successful.
