Repair concrete expansion joint
Old 10-14-14, 09:05 AM
H
concrete driveway has expansion joint where it meets garage floor. Expansion joint needs to be replaced. Do I use the type of fibre expansion joint or is there a better way?
Old 10-15-14, 03:55 AM
Received 1 Upvote on 1 Post
better way - remove exp jnt, install closed-cell backer rod, then seal per directions on sealant tube,,, we use either 100% silicone OR NP 1 ( more color options ) but all you'll find @ apron/vest stores is gray,,, sealant should NOT come in contact w/tires !
Old 10-15-14, 04:14 AM
H
Thanks!
When I remove the old expansion joint, should the empty space be filled with something before I install the backer rod?
Old 10-15-14, 04:17 AM
Received 741 Upvotes on 647 Posts
It depends on how deep the void is, often the backer rod and caulk is all you need. You could pour sand in and then insert the backer rod.
Old 10-15-14, 04:23 AM
H
OK, I was thinking using sand. I will do it today.
Thanks!
Old 10-16-14, 08:36 AM
i wouldn't especially where there's movement of conc either from freeze/thaw or HOT temps during the day & cool 2 nite,,, conc changes dimension in response to temps,,, sand may be forced upward by expanding conc thereby risking sealant's adhesion - not a good thing - we'd leave empty space instead but its your house,,, IF you absolutely positively have to fill that space, use vermiculite
Old 10-16-14, 10:16 AM
H
Thanks for the info. I decided that sand wasn't a good idea so I am leaving it empty.
Old 10-18-14, 03:11 AM
good man ! ( this is just ' filler ' as the original congratulatory phrase was too short to suit forum rqmts ) [ now twiddling thumbs awaiting for this insane ' time rqd to repost ' is up ]
btw, sand is NOT a compressible - that's why its unacceptable !
