What material was used for the bedding of my patio?
Closed Thread
Old 11-01-14, 08:19 AM
I am not sure if the sand was washed away by the water that is going under the patio in that corner or the bedding material is simply missing here. The paver below is from the left circled area in the second photo. That corner is actually raised a little bit which is the opposite that should happen if the sand was washed away from under the paver. So ...what material was used for bedding here? Can I say that the bedding is missing?
Old 11-03-14, 06:34 PM
Temporarily Suspended
This is the 3rd thread that you have started about your patio. The patio needs to be redone from scratch. I'm not going to answer anymore.
Old 11-11-14, 06:07 PM
How would you grade this patio?
This is about a cement pavers patio.
On the figure below the yellow arrows show how the lot is graded
For grading the patio I seem to have two options:
-along the blue lines
-along the red line
Which gading direction is recommended?
Bigger picture here: http://i.imgur.com/osVM8Ti.png
Old 11-11-14, 06:27 PM
Norm201's Avatar
Received 72 Votes on 67 Posts
Along the blue lines. _______________________________________
Closed Thread
