Drain
Old 12-20-14, 08:38 AM
U
Drain
We had the drain coming from the roof replaced this summer by the same folks that repaved our driveway. I keep seeing a small streak of water that seems to come from where the asphalt meets the PVC pipe. Any idea where this water is coming from? Thanks in advance.
Name:  20141220_112226 resized.jpg
Old 12-20-14, 08:43 AM
P
Temporarily Suspended
Does the PVC pipe go into a dry well? Look for a hairline crack in the pipe.
Old 12-20-14, 09:23 AM
U
Thank you for your response. The drain meets up with another drain and empties into the street. I looked pretty closely and did not see any cracks. I will look again. If it is cracked would in need to be replaced?
Old 12-20-14, 09:43 AM
Received 4,097 Upvotes on 3,680 Posts
You may have a hard time removing the piece that goes into the asphalt but it almost looks like there is a clog in the underground drain and it's filling up and leaking out.
Old 12-20-14, 10:07 AM
P
If there is a 90 degree elbow there, the water just can't flow fast enough. It could also be partially clogged as PJmax said.
