Cold weather concrete placing
Old 01-26-15, 03:17 PM
Received 1 Upvote on 1 Post
Old 01-26-15, 07:10 PM
BridgeMan45's Avatar
Received 2 Upvotes on 2 Posts
The article makes a blanket statement about adding accelerators, but doesn't go into any detail in describing them. Some accelerators contain a significant amount of calcium chloride, which can cause concrete performance problems, such as increased corrosion of steel reinforcement (rebar and/or wire mesh). A good practice would be to use concrete from a supplier using only accelerators approved by the state DOT, as most have done extensive lab testing of all concrete additives on their approved product lists.
Old 01-27-15, 04:34 PM
L
When inspecting in our area, if a truck pulled into a job with a bag of Calcium Chloride we made then leave!
Old 01-28-15, 09:46 AM
you're both right of course,,, GaDOT allows CaCl to be added onsite,,, iirc, 1 1/2% flake,,, NYSDOT had allowances for liquid accelerators,,, its not an in-depth article, guys,,, & yes, on public $ jobs, everything came off the dot's approved materials lists
