Masonry Adhesive for Sill Installation
Has anyone used masonry adhesive to join concrete sill sections end to end. the sections are about 2 feet in length??
Thanks
SudCaper
Thanks
SudCaper
Sure. There are many sealants that would work well for that, but not knowing your country of origin, or the products available there, it's hard to say.
IF you intent is to seal the section's interface, a joint sealant will work well,,, IF its your intent to join the conc sections to each other, you'll need epoxy & steel
