Cutting Concrete Block in Half?
Old 03-29-15, 02:41 PM
C
Question Cutting Concrete Block in Half?
I built a raised garden this weekend using concrete wall blocks (link to them below). Looks fine except that the two ends could each use a half block for a clean look.
Is this something I could easily do myself? Or where could I take it to have it cut?
12 in. x 7 in. Savannah Concrete Wall Block-81127 - The Home Depot
Thanks.
Old 03-29-15, 03:28 PM
P
Temporarily Suspended
Normally a wet saw is used to cut that. Since you only want to cut 1 block, you could put a masonry blade on a circle saw.
Old 03-29-15, 03:32 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
I'd use a diamond blade in a circular saw. If that is to pricey you could use a masonry carbide blade but because they get smaller as you cut you may need a couple. Cut from both sides and if that still isn't deep enough snap with a thin wide cold chisel.
Examples: http://www.homedepot.com/p/RIDGID-7-...70CP/202882332
http://www.homedepot.com/p/DEWALT-7-...712B/100018091
http://www.homedepot.com/p/DEWALT-7-...3521/202579871
Old 03-29-15, 04:47 PM
Received 75 Votes on 70 Posts
Or just buy a 1/2 block the same place you bought the other blocks.
Old 03-30-15, 04:23 AM
Received 301 Votes on 267 Posts
I doubt a masonry blade on a skil saw would cut all the way thru but if you make a score cut you can use a wide brick chisel to finish breaking it in to. If it wasn't for the lip, I'd just use the chisel.
Old 03-30-15, 12:00 PM
Received 1 Vote on 1 Post
we just finished a 200' x 6' retaining wall of those things,,, we used a demo saw w/dri-diamond blade but that's because we own 3,,, IF i were you, i'd get a 4" grinder & 4" diamond blade,,, saw ea side 1" deep which is all it will do,,, hammer off that piece & finish w/more saw cuts
Old 03-30-15, 02:01 PM
If you only have one or two cuts to make operatives look around for a construction site where they are doing ornamental stonework. I'm sure they'll have a large wet saw for their work and if you ask nicely and offered them a couple of bucks I'm very sure that they would cut it for you! Much easier, safer and probably cheaper than trying to do yourself.
Old 03-30-15, 05:42 PM
BridgeMan45's Avatar
I'd use a 4" angle grinder with a cheapo, $3 masonry blade, finishing off with a brickset and small maul.
