concrete ceiling swing install
Old 04-04-15, 11:20 AM
T
im trying to install a swing/heavy bag that can handle about 250-300 lb.
i have a concrete ceiling. its about 2.5" to 3" thick, then its hollow after that.
i was gonna install wedge anchors but im not sure i can do that anymore.
how can i install my swing in the ceiling.
here are some pics...
http://i261.photobucket.com/albums/i...404_140958.jpg
http://i261.photobucket.com/albums/i...404_140950.jpg
Old 04-04-15, 01:03 PM
ray2047's Avatar
Toggle bolts would be my suggestion if it is really reinforced concrete but the thickness leaves to think it may not be real concrete.
Old 04-04-15, 02:17 PM
T
the first hole i started drilling i had to stop because there was a metal rod stopping me .
Old 04-09-15, 05:54 AM
Received 1 Upvote on 1 Post
try moving the hole 3" to avoid the rebar,,, the ceiling may be a hollow precast conc plank,,, wedge anchors usually list pullout strengths on the package,,, shear strength would be found on the co's w/site
Old 04-12-15, 08:54 PM
BridgeMan45's Avatar
Received 2 Upvotes on 2 Posts
Keep in mind that a swing involves a dynamic load, instead of just a static load. Meaning you want to use a product that can withstand moving forces.
Old 04-15-15, 04:29 AM
good point, bdge
Old 04-15-15, 05:20 AM
E
Received 5 Upvotes on 5 Posts
Do you not have access to the other side ceiling? What about anchoring to a rebar intersection. That's how our chandeliers are hung (a figure eight type loop with one end in the light box and the other around a piece of rebar) granted its not a dynamic load but we have a one in that weight range.
