Dip in small slab
Old 04-06-15, 06:51 AM
E
Dip in small slab
I have a small slab under my front porch (porch is 9' up) and the slab has a 4' by 2' dip in it and is holding about 1/4 to 1/2 inch of water. I am wondering what is the best product and easiest to install to level this spot. It does not have to be perfect but I don't like holding that much water.. This product only needs to hold 300lbs.I have a bottle of thin set mortar add-mix that a contractor left and was wondering if that can help in this situation?
Thanks
Mike
Old 04-06-15, 07:03 AM
P
Temporarily Suspended
I think that you would be better off with a type N mortar mix but I would use a bonding agent with it. I've used it on a stoop & it worked well.
Old 04-08-15, 05:18 AM
E
Thanks Pulpo! I will read more about that
Old 04-09-15, 05:09 AM
Received 1 Vote on 1 Post
we just raised an extreme depth bird bath (3") in an exterior 12' x 12' driveway slab using a apron store product called ' cement all ' ( i think ! ),,, prep was pressure wash & blow dry - 10b worked fine & cars drive/turn over it every day probably not as inexpensive as previously posted product but anticipated use/service is more extreme imo
( no $ interest )
