Fire Pit Foundation/Stone Questions
Old 04-15-15, 08:02 AM
So I have decided for my first landscape job as a new home owner, I am going to take a crack at making a fire pit.
I have been scouring the internet the last few weeks for steps/advice and I have some questions I would like answers on. It seems these things have contradictory advise from different sources.
1. I would like to build with the stone/mortar look rather than dry stacking, should I go with a cement foundation or gravel?
2. How deep do I need gravel in the center for drainage?
3. I would like to line the inside with fire brick, are those just the packs of 6 or whatever I can grab from the hardware store in the fireplace area? Or is there a better kind of firebrick to get?
4. Is there any ventilation needed in the foundation/wall? I would like to avoid any potential explosions if possible.
If anyone has any other tips from their own jobs, that would always be appreciated. I am a planner, and I wont act until I have thought of every scenario.
Thanks!!
Old 04-15-15, 09:26 AM
F
Received 35 Votes on 27 Posts
Concrete, not cement, would be permanent if it was placed below the frost line. I'd be tempted to use a bed of crushed rock a minimum of six inches thick and well tamped.
All the way to China. Seriously, this depends upon the soil conditions. A drain line, I would use no less than 2 inch ABS or PVC, run with a slight downward slope to daylight would be ideal.
I would discourage the use of firebrick. It is highly unlikely that you would have a fire hot enough to require the use of firebrick and firebrick is porous enough that it would absorb water. This water, if not evaporated out prior to building a fire will then turn to steam and cause spalling (chipping) of the firebrick.
Yes there is. You need to have air inlets low down to allow combustion air to enter below the grate (if a grate is used) or you will have poor combustion. A few higher up the wall will also help in combustion. Leaving the vertical joint on every fourth brick or so without mortar (about a 1/4 to 1/2 inch wide) usually is sufficient.
Are you planning on having any kind of gas ignitor or burner in this firepit?
Old 04-15-15, 10:14 AM
Thanks for all the info, that is basically what I was looking for.
I will not have any gas igniter or anything of that sort, just your basic fire pit. I may or may not have a grate on top, if I do I would just rest it over the pit when needed, not built in. I will make sure to leave a few vents in the wall when building though.
