Filling hole under concrete stoop
Old 04-24-15, 11:55 AM
A
Hi folks,
I saw a couple threads on this, but I'm still unclear on the details. I'm very new to any kind of DIY stuff.
We have a concrete front stoop. Three steps, small porch, all one piece. the porch is not tied into the foundation of the house. see picture below.... The house was built in 1997, we bought it last summer. The home inspector pointed out that there are visible gaps under the concrete.
I'm pretty sure we need to fill those gaps, but I'm unclear on how. I read about "slab jacking" but that sounds like overkill for this. I also read about filling the holes with gravel or cement, but to do that right you need something to hold the gravel or cement in place, right? Do you dig down and build a form or something?
Size:  49.8 KBName:  stoop2.jpg
Thanks for the help!
Old 04-24-15, 12:00 PM
Received 800 Upvotes on 703 Posts
Old 04-24-15, 12:30 PM
A
thanks! for some reason it wouldn't upload as jpg but png worked...
Old 04-24-15, 01:51 PM
P
Temporarily Suspended
Has the stoop sunk or shifted at all? Put a level on it, if you can't tell by eye. The stoop should have footings 30" deep there although that wouldn't explain why the land would wash away.
Old 04-24-15, 02:26 PM
You could probably get by with digging down to solid ground under the edge of the concrete and pouring concrete in the hole ..... be sure to make sure nothing has sunk first
Old 04-24-15, 02:48 PM
A
Thanks!
It is *pretty* level... according to the level on my iPhone it is 1 degree lower on the side that has the hole.
And, stupid question, but what do you mean by "dig down to solid ground"? What's the difference between solid and unsolid?
Old 04-24-15, 02:50 PM
If you pour concrete on loose ground it will likely erode sooner or later. Stable ground might have been a better description.
Old 04-24-15, 02:55 PM
Received 1 Upvote on 1 Post
according to your pic, try a 2x4x18", compactible granular base, & a 3# hammer - you can probably figure out the rest
Old 04-24-15, 03:59 PM
A
...does that mean I should dig out that size of a hole, put gravel (compactible granular base) in it, and... hammer it?
Sorry to sound stupid, but this is all greek to me.
Old 04-24-15, 04:08 PM
P
That's how it translates from Greek. I would use an 8" diameter sono tube cut to 30" which is your frost line & fill it with Quickcrete concrete mix. A sono tube is a cardboard tube available at Home Depot. Quickcrete concrete mix is also available at Home Depot. You might need two bags. Just add water while mixing it until its the consistency of sherbert.
Old 04-24-15, 04:21 PM
A
you guys are so helpful!
So, Pulpo..
...do you mean that vertically? dig an 8" by 30" vertical hole, put the tube in it and fill it with quickrete? Or horizontally? I figure you must mean vertically since you mention the frost line. So that would give me a footing of sorts, but not all the way up to where the stoop ends, right? I fill in the rest with gravel?
Old 04-24-15, 04:50 PM
P
You were right the first time. The 30" is vertically. That's the frost line in your area. Cut a dip on one side of the tube so you have room to pour the mix but at the same time. When you get to the top, let the mix set a little. That way it will stay there as you bring the cement up to the bottom of the stoop. Gravel can go on the outside of the tube but it's not needed. Don't put it inside.
Old 04-24-15, 09:29 PM
BridgeMan45's Avatar
Received 2 Upvotes on 2 Posts
How do we know what her frost line is? She hasn't told us where she lives or completed her profile. If she lives in a southern state, the 30" deep value is way overkill. If that's the case, I vote with stadry, and would just ram crushed gravel into the voids using a long 2 x 4, smacking the end being held with a 3-lb. maul. Easily accomplished in a few hours at most. And far less chance for complications from improperly installing concrete in sonotubes.
Old 04-25-15, 03:58 AM
P
She didn't have to say where she lives. That's my expertise. The frost line is 30". If you think that the gravel is a better idea, give her step by step instructions.
Old 04-25-15, 10:01 AM
You are indeed a gifted fellow, Pulpo, knowing the frost line in her area without even knowing where she lives.
Old 04-25-15, 10:11 AM
If I remember correctly the frost line in central fla is 8" not that ever gets cold enough to freeze that deep but I've heard of northern climates being 4' .... maybe Pulpo has a crystal ball
I still think digging down to solid ground and either using concrete or packed gravel [latter is probably better] is all that would be needed.
Old 04-25-15, 11:07 AM
i'm not seeing any holes so perhaps this monitor's not worth a ****,,, looks to me like backing up shoulders or a sidewalk,,, are we making more of this than necessary ?
no, you do NOT dig out the hole - just put a shovel full of gravel next to the open space & start compacting w/2x4 & hammer,,, why dig out something you already have ? just be careful of that green snake,,, it looks like a 50 footer ! ! !
how could anyone even measure a frost line in fl ? even in atl, we don't get frost depth
missy, do us all a favor & tell where is your ' where ' - thanks !
Old 04-25-15, 07:45 PM
P
Who said anything about Florida? That's not where I think she lives but since she wanted to be anonymous, I didn't mention it.
Old 04-28-15, 09:50 PM
P
So it looks like Angela, the OP got spooked when she was asked to reveal her location & hasn't returned. For those who want to stay anonymous, using your maiden name & omitting your location isn't enough, especially when you post a pic of your stoop. She lives in MD, hence the 30" frost line.
Old 04-28-15, 10:50 PM
Once again, I'm simply amazed by your vast wisdom, Pulpo. Being able to determine a state of residence just by looking at a few close-up pix of a front stoop, is indeed a gift--something that us mere mortals can't begin to comprehend.
Any chance you'd be willing to share with us this week's winning Powerball numbers?
  #21
Old 04-29-15, 07:45 PM
P
You just don't realize how important stoops are in tracking people. There used to be a guy in Cottage Grove who had powerball #s but he just can't do it anymore.
