Sealing a 4" diameter dryer vent hole
Hi,
I have an approx. 4" diameter hole though my foundation that was used for venting my dryer (I assume). Currently the dryer is being vented elsewhere, so I'd like to "repair" the hole. It's not a structural problem so I'm thinking that I won't need to fill it with concrete etc. It's around 3' above grade, so I'm not worried about water that much, but just want to stop air (heat/cold) loss.
Is there some type of plastic/rubber "cap" that can be placed over the hole and then sealed?
Thanks
Thanks
What is the wall made of? You posted in the masonry section of the forum. Does that mean the wall is brick, cement block or concrete?
My unprofessional opinion would be to stuff some screen wire or whatever in the hole as a backer and then apply mortar to it. That way the finished job while visible will look similar to the rest of the wall [assuming it's poured concrete]
almost forgot
welcome to the forums Dan!
almost forgot
