cinder block gate post?
Old 06-30-15, 12:39 AM
9 blocks high. 2 blocks at each level. 16 inch blocks. Supporting 6 ft by 6 ft chainlink gate.(2 *6 ft gates covering 12 ft driveway). I would drill hole in cinder block to receive gate hinge.
Or should i use steel post and have block pier in front of steel gate post. I plan to stucco cinder block post later. Thanks.
Old 06-30-15, 03:15 AM
chandler's Avatar
Received 2 Votes on 2 Posts
Not a concrete pro, but you will be exerting too much pressure for the walls of a cinder block to hold a gate. It will most likely bust out. I would sink a gate post beside the column to hold the gates, and decorate the block pier any way you wanted.
Old 06-30-15, 02:07 PM
I was going to fill blocks with concrete and rebar. I dont have skill to make concrete post.
Old 06-30-15, 03:11 PM
chandler's Avatar
Not a concrete post. A metal chain link gate post. You could fill the blocks, then drill for an "L" bolt and epoxy it in.
Old 06-30-15, 03:22 PM
6' gates that swing can put some loads on any post.
How deep do you plan to dig for a stable post that will not deflect and make the gates misaligned and then have closing or appearance problems. 1/4" times 2 posts will reduce the gap between the gates by 1/2".
Dick
Old 07-02-15, 12:15 AM
Thanks for replies. For a cinder block gate post, i would dig down about 3 feet in hard gravel and fill with concrete
With rebar sticking out to anchor blocks. I have 2 ft lengths of railway
Track i might use in hole.
I also have 15 in diameter cedar logs i could use but they rot and diameter gets smaller at top end.
