Need advice on pouring concrete steps
Old 07-03-15, 07:18 PM
Looking to make 2-3 steps down into my crawl space and get rid of the cinder blocks.
- Should I make a form and pour it as one big block or, 'layer' it?
- Would it be advised to anchor it to the foundation? If so, how?
Thanks
Old 07-03-15, 07:51 PM
Temporarily Suspended
If you insist on building concrete steps, why not use the blocks? It will save a lot of work. Flip the blocks up the way they are supposed to be & fill them with concrete.
If you are opened to other suggestions, I would go with
https://www.masters.com.au/media/MAS...9NXyyZraP1.jpg
Old 07-03-15, 08:08 PM
BridgeMan45's Avatar
If you want something permanent, form and pour a series of concrete steps, in place. You can anchor the placement with a few heavy lag bolts and lead shields, into drilled holes in the stem wall on each side.
Quicker and easier, although not as permanent, would be to build the steps out of wood.
