self-leveling concrete mistake that needs to be fixed. but how?
Old 07-27-15, 07:45 AM
hi gang. so here is the deal. I hired a guy to help level my concrete patio. water was pooling, he was going to get the slope better so it ran off the side into a new drain in the low spots. before doing another skim-layer topcoat all over.
he tried a couple different brand of self leveler but either didn't mix it right, work fast enough, was too hot out or how didn't know what he was doing.
so I come back from my short trip and the work isn't done, he cant be found and there is a 5 foot by 7 foot area where it looks like he tried make it work but quit.
so assuming I cannot find him, what do you recommend? will I have to just chisel this off? is there a grinder wheel attachment or anything I can get for my angle grinder or drill? A buddy said they rent commercial concrete grinders at Sunbelt (about $75/day) but they chew through wheels quickly supposedy. Or is there a chemical solution? gotta get this cleaned up as now it looks worse than before he began.
photo attached. as always, thanks!
Old 07-27-15, 08:07 AM
Temporarily Suspended
You might be better off with a chipping gun than a grinder.
Old 07-27-15, 08:09 AM
Received 203 Votes on 188 Posts
If you want to try removing it I would start with a rotary hammer set to hammer only and use a chisel bit. It's powerful enough to knock things loose but but not so big that you might damage the slab underneath.
Old 07-27-15, 08:21 AM
ok. chipping gun I might actually have one. rotary hammer is new to me. Let me look into that.
thanks
Old 07-28-15, 02:22 PM
BridgeMan45's Avatar
The guy you hired obviously didn't know what he was doing. I hope you haven't paid him already.
Renting a small scabbler would make short work of removing the mess and getting down to a sound surface for new material to bond to. Using a bush-hammer would work, but take considerably longer.
Old 08-01-15, 01:56 PM
the scabbler would be ideal but, even in atl, the only thing we can rent is a walk-behind,,, IF you have walk-out access to the patio, good - otherwise they weigh more than 300# & need 185cfm air compressor,,, even hand-held scabblers need 50cfm for efficient operation,,, hardly what a diy guy wants to hear,,, chipping gun &, IF you can find it, bushing tool - preferably 16point,,, otherwise, brick chisel as posted,,, looks like he didn't add enough water & used a shovel to spread it
std chipping guns are also called rotary hammers sometimes
