Making concrete sprinkler donuts
I would like to make my own concrete donuts to protect our sprinkler heads - they are not available in stores around here.
I suppose it might be best to bring one back from the States to act as a template. It might be easier for me to make a mold out of metal or maybe wood rather than plastic. Is there something I can coat the mold with to help in removing the donuts when hardened ?
How would you go about it ?
Thanks
Thanks
Grease, oil or non stick cooking spray can help prevent concrete from sticking to your mold. You could use a pound cake mold. The tapered sides would help getting the cured concrete to pop out.
I've never seen a concrete ring used to protect sprinkler heads anywhere in the states. I've had sprinklers at my last 3 homes, never had them nor have I had a problem with any of the heads. I've also never seen them on any of the golf courses I've played over the years. Do you have a special situation where you need to do this?
do what we do in atl & hilton head - use sprinkler heads that pop UP when working
off the clock, they retract below grass height
admittedly the bundt pan's a genius suggestion,,, i would only add using saran wrap will make cleaning the pan unnecessary before sneaking it back into the kitchen
