Exterior Foundation Crack & Interior wallboard separation
I have a crack in my cinder block/concrete foundation that now has transferred to the wallboard inside. I'm fairly certain that the foundation crack is continued settling, and I was looking for suggestions for a flexible filler for the exterior crack. And is there anything similar for wallboard repairs?
Cracks in drywall are normally fixed with drywall tape and joint compound. You don't normally want a flexible filler on drywall. How wide is the crack in the foundation? Is it all above grade or does it also go below grade?
elastomeric SEALANT, NEVER ' caulk ' (as in the noun),,, masonry section of apron/vest stores [np1 - non-sag],,, got a bsmnt ? the crk will eventually lengthen if the cause is as you've determined
pro mtls + tools + methods + knowledge + skills = pro results
if you're talking about latex deck stain, i agree - its really paint,,, caulk's different than sealant & picking/knowing the difference's critical to successful performance,,, caulk can take full-sided installation - sealants cannot
