driveway drain
driveway drain
any suggestions for a frame & grate for middle-of-driveway ? all i know is municipal/dot frame & grates or traps,,, may be forced to gang some slot drains.
thanks in adv.
thanks in adv.
So what's wrong with installing something (DOT or municipal) that can easily resist the loads of a large truck making a driveway delivery?
If you want flimsy, drill a few holes in the bottom of a plastic bucket, embedded in the wet mud with the holes down, and then lay a bbq grilling rack on top of it, tie-wired in place.
not MY d/w, bdge,,, as usual, clients' budgets are somewhat restrictive,,, we may wind up sawing an opening, inserting a pre-cast 1.5 x 1.5 x 2.0 conc sump & securing ( Fiberglass Grating - Square and Rectangular Mesh Details ) or ( Perforated Metal, Wire Mesh, Grating, Expanded Metal and Fiberglass Products. ) - the latter's local
thoughtful of you as always tho - tnx
From the standpoint of reducing callbacks, I would have thought you'd avoid going the "cheap and flimsy" route. And if the client's budget is the issue, why not install a quality product, and just reduce your 500% material markup?
FOUND IT ! played hookey w/bride yesterday for a round of golf & VOILA ! a fairway lawn drain w/cast iron grate & conc cylinder box for a base !!!!!!!!!!!!!!! who wouldda thought ? ? ?
500% markup ? i wanna work for you
we normally work on 40% +,,, 100% markup would be 2x project cost ( materials, equipment, travel, labor & labor burden )
