material with adequate drainage for sitting area under tree
Old 11-16-15, 12:00 PM
Hi,
I have a large tree in the front yard. We sheet mulched a lot of the area; then we went back and removed the grass from the area around the tree. Now we want to put in a sitting area. Not quite a patio. Maybe a couple benches away from the crowning of the tree roots (bottom left of pic below).
We're well inside the drip line, but I still don't want to have a highly compacted material in place (no pavers, etc.). I've seen some sites recommend decomposed granite (DG), some with a 2-3" layer of road base and then DG, and some with just a gravel fill.
First priority is to avoid damaging the tree, so adequate drainage (i.e. low compaction) is important. Putting up a deck is not something we want.
Any thoughts / suggestions? I'm in Sacramento, should that make a difference.
Thanks,
michael
Old 11-16-15, 01:29 PM
a 3/4" washed stone would probably work well. It is big enough not to compact tight, but small enough the be level and stable to walk on.
Old 11-16-15, 02:05 PM
Received 1 Vote on 1 Post
River rock would be another option. Pretty similar to washed stone. Comes in different sizes and colors, and is rounded so it doesn't compact and is foot friendly.
Old 11-17-15, 06:20 AM
Thanks, guys. Good ideas. We'll probably pursue some kind of 3/4" rock area - I'll try to post picture when we're done.
I imagine we should put some landscape fabric down to try to prevent weed growth?
Thanks again.
michael
Old 11-17-15, 06:27 AM
Yes, you will want some geotextile fabric under it to help limit weed growth.
Old 11-17-15, 06:49 AM
Good idea, and it will prevent the stone from gradually sinking into the soil. Since you're in CA, you may want to stick with a lighter color stone so you don't overheat the roots of that nice old tree.
