Stamped concrete with wall
Old 04-25-16, 07:20 AM
E
I am looking to get a contractor to pour a stamped concrete patio. I would eventually like to put up a stone wall myself around its perimeter. Should I have the patio extended for the wall to sit on? Or is it better to add it later if needed and separate it to reduce stress on the patio concrete.
Do these walls normally sit on concrete or just packed ground and gravel.
Also if I wanted to run electric is it better to do it after the patio is poured or run piping under the patio?
Thanks!
Old 04-26-16, 02:39 AM
Received 1 Vote on 1 Post
what do YOU want ? a wall sitting on a conc patio OR on its own foundation ? both are possible,,, if you'd put your 'where' as rqst'd, would've help'd responders post semi-intelligent answers,,, power's up to you, too - you want exposed wires or conduit under the conc ?
