Holes in Stucco
Holes in Stucco
My cousins house has holes where wood was to make it look like a southwestern style home. Well the wood was rotted and was pulled out so now there holes. It's a standard framed house with brick exterior and then covered with stucco. The holes go through to the interior drywall. I'm thinking of some spray foam and/or foam board insulation using construction adhesive and a stucco material to cover/match. The holes are each about 5x5 inches. Thoughts?
I think what you are supposed to do is tack up stucco wire and then apply 2-3 coats of mud but what I'd be inclined to try [painter not a mason] would be to mud in a piece of cement board, let it dry and then go from there.
Hopefully one of the masons will chime in with better advice for you.
