Tapcon concrete anchors for concrete
I purchased 1/4" x 1 3/4" tapcons. The label underlying on the box says I need 3/16" x 3 1/2" masonry or Tapcon bit.
The width is correct that needs to be smaller than anchor width. But it says about 3 1/2" drill bit.
I plan to use the whole length of tapcons ...1 3/4 " long.. Do I need to go all way down to 3 1/2" with drill bit? I know common sense says no.
No.... you can just go slightly deeper than the tapcon length.
The bits are longer so as to accommodate the longest tapcon size. Sometimes the length comes in handy when you drill thru a board into the masonry.
You can put tape on the bit as a stop point or I have premade picks that I put into the hole to check the depth. You can use a 16D common nail too.
Agree, about 1/4" extra is good. I've found you need to blow the dust out of the hole after drilling, especially if you are drilling the floor for a wall plate or whatever. Not so critical on walls. Otherwise the dust will interfere with the fastener seating all the way or cause it to strip.
Thank, Pete.
Another thing pops up after the posting. Are they tapcons really anchor screws? Typical anchors' legs flare up when tightened. These tapcons look normal; threads may have longer outer diameter.
Tapcons are case hardened fasteners. They are a one shot thing. If you install it in a hole and need to take it out.... the fastener and the hole should not be reused.
Use any kind of empty squirt bottle like an old condiment bottle to blow the dust out.
Some dust left behind is ok.
You drill the hole deeper so that the dust and particles of concrete that the screw sheds will have a place to fall. I drill the holes a good 1" deeper than the screw to make SURE nothing will make it bottom out. I have never blown dust out of a tapcon hole. http://www.tapcon.com/support
You need to make sure the hole is clean if you are using a different type of anchor that uses epoxy.
Blowing concrete dust is not good anyway. (Silicosis) Vacuuming is better. Water would probably just turn it into cake in the bottom of the hole. If i want to clean the dust (like if I need to caulk or chase the screw with caulk), I wIll vaccum as i drill... running the drill up and down many times to finally clean the hole. It also helps the screw go in easier if you run the drill up and down a few times as you clean the hole.
I cannot deny vacuum is cleaner. I appreciate your explanation is good for big projects. Mine is small, but pain in the rear. You may wonder what I am up to with tapcons. I had tried pick axe and sledge hammer to break up and loose Belgians on curb, but it's no fun and too physical. The Belgians are loose, but still stuck in the ground. I had thought about getting someone to get rid of 6 Belgians.
But I decide not to and try to outwit it by doing something else by exhausting little physical or none. And I want to get the job done by myself since small and I want to enjoy the project. So I gave thought about putting a wood plank on top of Belgian and screw with two tapcons. [I will have to drill wood first with different bit.]Place the screwed Belgian with wood on top between two hydraulic jacks. Then jack them both one at a time to push the wood plank upward and get belgian.
It will take much longer time cuz I will have to do one Belgian at a time. Six of them. Maybe I can experiment with tapcons and see if it can withstand the pressure of jacks pulling Belgian out.
If it fails, then I will get somebody to do few whacks.
What do you mean by Belgian? Around here, that would mean a very large draft horse. That doesn't seem to make sense.
I have lifted concrete with tapcons. I cut the concrete into small 3x3 sections then I attached a short piece of steel to each one- screwed a tapcon into each end of the steel then used a chain and a skid loader to lift them up and load them in the truck. Worked like a charm.
I believe he's referring to Belgian blocks. Those blocks are too hard to use tapcons in.
You're kidding me.... take a sledgehammer and hit those blocks. I'd have them out in a few minutes.
This thread is in reference to this thread..... http://www.doityourself.com/forum/br...eway-curb.html
MS International Belgium Block 4 in. x 8 in. Tumbled Granite Cobbles-LHDCOBGBELBLO48 - The Home Depot
Belgian Blocks. I would like to have a horse in my backyard
Really? Tapcons cannot be in Belgian blocks?? If not, I learn the hard way.
There is an error on my part. Belgian blocks are granite, not concrete. Big difference. Looks like I cannot use tapcons.
You are completely losing me.
Why can't you take a sledgehammer and just hit the blocks breaking them loose from the cement ?
Maybe I'm missing something.
New challenge. More fun and will do whacks for me. July 4th weekend. Holiday. You may be missing something.
DEWALT 1/4 in. Diamond Drill Bit-DW5572 - The Home Depot. It's expensive bit, but it will do the work. Then use machine screws anchors. Not tapcons. You are correct tapcons are difficult to drill.
