Saw for cutting Brick
Hello,
I'm new to the DIY projects. I have keystone bricks that i would like to use in the backyard for a nice patio. What kind of saw do I need do cut or trim bricks that need to be adjusted?
Any help is greatly appreciated.
If you only have a few cuts, you can use a dry cut diamond blade in a circular saw or an angle grinder. If you have quite a few (typical for a patio) you may want to rent a tub saw with a wet cut diamond blade. It can be messy, but does a beautiful job.
You can also cut them with a brick chisel and a small sledge, but be prepared to waste a few as it is not very precise method until you have a lot of practice.
