Drill hole for freeze proof sillcock
I need to drill a 1.25" hole through 8" of concrete.
Can this be done with a hammer drill?
Qwerty, I have the same project on my list. I don't want to come out through the rim and my new siding so want to go through the concrete.
Now, the concerns I have are running into some rebar. I know they used some, but that was almost 40 years ago and i wasn't paying close attention. I'll cross my fingers on that one. Where I have a three 1/2" drills, none are hammer drills, so when time comes I will hit the rental shop for the proper drill and bit. I am a frequent flier at one of my local rental shops. They have quality equipment in good condition and always friendly advice.
Bud
Bud
So SDS will be fine? I don't own a hammer drill so will be renting. A core drill seems a bit excessive but won't the drill bit on a SDS get hot without water? What type drill bit is needed?
Drilling an 1-1/4 inch hole through eight inches of concrete without using a core drill will leave a rather sloppy hole. You could use a twelve inch long 1/4 inch bit and make several holes and then break out the rest with a punch and chisel. Using a solid bit will take forever unless you have a really powerful (read large and heavy) drill motor. You could use a series of solid bits from 1/4 inch on up and do it a bit easier and quicker than using just the finished size.
No matter how you do it, it will take a fair amount of time going through that much concrete. That is why I recommend a core drill, a clean hole in a reasonable amount of time with a relatively easy-to-use drill motor.
